please help-screwdrivers
They're basically Allen hex wrenches with a ball at the end so you can drive the screw at an angle.
Does anyone know of a screwdriver set that will hold up under at least a small bit of pressure and will not twist, curl, grind, strip out, etc... which then causes premature screw failure. If my mind was in the gutter, the last three words of the last sentence could be a lil funny, any, back to the subject at hand. I've tried many brands and quality grades and still haven't found any that I really trust, so if you guy know of some that really hold up like they are supposed to I would love to know about them. Please help, I'm already having screw heads going bad and the truck is only a month old and has only been taken apart twice!
I had premature screw failure before my baby's rear fell off
i have Bondhus ball end hexes and they are great, but for screwdrivers i use my set of Snap-On minis i had in my tool box, they havent failed me yet. if you want the part number for that snap on mini screwdriver set i got ill dig it up, but as far as hexes go, i have no complaint with Bondhus. even the little 1.27mm ball end hex holds up
