Ok, I'm using my car right now. (In garden). 0-3/4 throttle is fine, when i go full throttle the engine stutters and will eventually fail. I try leaning it (turning clockwise) It gets slightly better, if i go too far the car gets stuttery at low throttle and cuts out, before that point the car is still not perfect. When idling, the idle is quite high and the clutch is slipping, i turn trim lower and nothing happens, too low and the brakes apply. The idle is erratic it will have bursts of high revs then go low for a bit then randomly high again. PLEASE HELP!
