craig911
hey guys,
its time to get a new engine for the tamiya TGS and I'm struggling,
i found one fairly cheap but it was rear exit exhaust other than that it would have been perfect.
i dont want to spend much cash on the new engine for the TGS around £40-50 ( would consider used )
i need help finding an engine that uses a P shaft crank shaft and side exit exhaust size .12-.18
it has to be P shaft as i need to use the tamiya pilot shaft and clutch bell,
The TGS clutch bell uses 2 different sized clutch bearings and will only fit on the tamiya pilot shaft and the clutch bell is the only one that will mesh with the gears in the transmission case
currently I'm using a thunder tiger .12 engine with the tamiya FS.12 crankshaft so if push comes to shove i dont mind switching the crankshaft again
so to reiterate and be too the point i need a engine between .12-18 that uses a P style crank shaft and side exit exhaust
