Yeah, had the same problem. Eventually went to 14/38. Kept the nose down but still had my top end.
Monkey Wrench said:Yeah, had the same problem. Eventually went to 14/38. Kept the nose down but still had my top end.
Monkey Wrench said:Either works fine. I personally pinch the line, but some folks throw a rag into the flywheel or use an old screwdriver. There's been some debate on this, with some feeling pinching the line may cause some damage because it leans the engine out for a bit, but I feel if you're tuned right, the lean condition only lasts a few seconds and that, in and of itself, is not enough to damage the engine.
Or do you mean 36/16: 2.37 ?
which fuel are you using ?
Monkey Wrench said:Whoops! My bad, forgot I changed over before I went to WATCH other people race a few weekends ago. Yup, that's what I have in there now.
Trinity Monster Brew
econ1111 said:do you know SIDEWINDER 20% NITRO with 12% oil?
my local dealer make the break in procedure with this fuel and he told me to use it without AFTER RUN because it has in it the after run.
what do you think about it?
Monkey Wrench said:Yes, I know what Sidewinder is and I know it has a lot of oil in it, but all nitro fuel has oil in it. The point is, as Olds points out, raw fuel, no matter how much oil is in it, will gum your engine up. After every run, I put a few drops of ARO in, spin the flywheel to make sure the P/S, bearings and conrod get a nice coat on them, put the piston at BDC and put my plug back in.
For the record, TMB has 20% nitro and 16% oil and they recommend using ARO after every run.
Monkey Wrench said:1. Empty the tank of all fuel.
2. Pull the plug, put a couple drops of ARO in there then spin the starter for a couple seconds.
3. Spin the flywheel so the piston is at BDC. Put the plug back in.
Do this after every run and that TM will last a long time. Whoever told you that you don't need to because you are using Sidewinder is misleading you. Even if the manufacturer states that, I still suggest doing these steps.
Enjoy that TM!
Monkey Wrench said:Yes, just make sure the piston is at BDC and you're fine!
jetmechG550 said:For the cost of a new p/s and rod you can just about buy a TZ or as olds said, get the 3.3. I've got probably 3-4 gallons threw my TM but I don't keep too much track of it, but it still runs great on track.
Monkey Wrench said:Yeah, same here and I didn't know people were having their TM's die after three gallons, so I'm wondering on that one. As for how mine runs on a track, hard to say because it hasn't been on one, but mine goes great when I'm practicing!
Frankly, if you take the time to care for your mill, it should last a fairly long time (I stress SHOULD). Manufacturing defects aside, keeping it from gumming up and preventing it from over heating are two keys in engine life.
econ1111 said:so all that i heared is only rumors ? and if i would takse care the engine and put after run ....after each run it will last about 10 galons?
