OS Carb Dimensions?
GilBeQuick
Where can I find the dimensions of OS carbs? I've been searching everywhere and still no luck.
What I really need to know is if the OS #20E carb has the same dimensions as the OS #21b carb? I know the RG's were discontinued and the RZ's replaced them, I wonder if the carb is just renamed the #21b. Anyone know? But if anyone knows of a page of the carb dimensions I can look it up. Thanks!
OS 20E
SPECS: Outer Throat Diameter: 15mm
Inner Throat Diameter: 13mm
OS 20b
SPECS: O.D. carb to engine mounting sleeve - 15mm (9/16")
O.D. carb to air cleaner mounting sleeve - 15mm with 16mm lip
Carb throat bore - 7mm (1/4")
Carburetor height - 47mm (1 7/8") including needle valve
" thickness - 20mm (13/16")
" length - 70mm (2 3/4")
As per TowerHobbies description...
You're the man, thanks!
Olds, as far as I know, just the #20e carb.
