BamaFan
ROLL TIDE!!
Does anybody know what the factory LSN and HSN on a os .21 tm is? How many turn out from fully closed?
Should be in your manaul under the carb section but this is what I found at towerhobbies.com. hsn 2 and a half turns. Lsn turn 30 degrees either way to richen or lean. Mid half turn in from flush. Idle screw is not noted on the webpage. These are also general settings and the manual should be used for accuracy.
