Well... running higher nitro generally means you need a cooler plug, but there isn't a cooler plug that is long enough for that engine.
This is the only one I could find at tower that's a "long" plug that is anything but hot. It's a medium temp. Traxxas HD Long
The TRX 2.5 and OS 18TM use longer plugs than the typical long plug. Thats why the 18TM comes with the LC3 which was designed for the 2.5 and the OS 18TM..
I'm not saying you can't just buy an OS #5 and not use it, but I doubt that it will sit flush inside the piston dome like it should.
Using o donnell 30% fuel with OS # 8 Glow plug w/o shim >>>Excellant response and cooling at 90 Degrees with 70% Humidity in this area...Real winner....:bow:
