I bought this engine used and it has no cylinder, piston, or rod...I bought the stuff (its the stuff from OS for the 18TM). For some reason the cylinder will not fit into the case, it seems like the case is slightly undersized. How do you get this thing into there...should i put some after run oil on it and see if it will go in that way? Can someone help?
Thanks,
David
Thanks,
David
