One way bearing help
Soulmaster12
northern Indiana
How do u take ou the one way bearing
is it possible becuase i think its slipping or its broken becuase the motor will only turn over like once or twice then it wont do anything when i turn the roto start. Now I've heard that it could be a leak in the gasket which i fixed and i also heard that the piston is stuck at the top of the sleeve. i also heard that the roto start adapter needs oiled. I've done all these things and havent tried starting it yet but i still need to know what the problem is and how to take out the one way bearing (if possibe). ;)
EDIT: I FIGURED IT OUT ITS AN EXTERNAL ONE THAT YOU CAN JUST PULL OUT.
Well... It probably would be helpful to us if we knew what the one-way bearing was ON.... I would suggest you consult the documentation on your RC and take off everything that looks like it is 'in the way'... the one-way-bearing should slip right off the shaft once you get to it... YMMV
:cool:
Moved to nitro section, may get more help here.
It would help to know what vehicle it is and what engine it is. Knowing this will tell us if it's an external or internal bearing. Each have their own issues and the resolutions may differ some.
5
easy rider
Basher_around_town
1
tudordewolf
tudordewolf
