Hey!!
I just got this broken in but some advice needed...
During "extended" accellerations the engine is loosing power just as if it was too lean (and it is not).
Temps are good and everything seems fine. (220F w/o and 270F with body on)
LSN seems OK because of good punch off the line and regarding the HSN I think it is good.
I have noticed some small bubbles or atleast foaming in the fuel line to the carb. I have changed it out but still occurs.
Pheew finally to the question (sorry all but intro needed).. When I changed the fuel line i made the same routing and hence the same lenghts... This way of routing the fuel line and backpreassure line seems way too long for me. (Have inferno 7.5 also) Did anyone in here shorten them. Especially the one going from tank to carb.. That is only about 2" on my Inferno but at least 5" on the LX Comp...
Could this cause the inconsistant fuel supply ???
I suspect this to cause the cutting/power loss/erratic behaviour (sp)
Kind Regards from Denmark
