I picked up a second hand Mayhem a couple weeks ago. I just got around to trying it out Sat.
Fired her up and headed to the street for some shaking out. After my third or fourth pass, I turned it around hit the gas and nothing. I walked up to the buggy and tried turning the wheels...worked fine....T/B nothing.
Off to the bench. I wanted to see if it was a dead servo or maybe a rcvr problem. I plugged the T/B servo into the steering slot and turned the wheels on the TX...nothing. I plugged the steering servo into the T/B slot and pulled the trigger....wheels turned. From this I decide the servo is dead. At this point I switched my attention to other things.
Monday; I dig around through the boxes and find a stnd servo to put on the Mayhem. First though I give the old one another chance...who knows maybe I didn't have it shoved into the RX far enough :shrug:
Low and behold it works....back to the street....quits working a minute later...I reach down and manually work the throttle to keep it running....servo starts working again.....minute later dead....manual pull...starts working
Is this symptoms of anything in particular?
The other odd thing this buggy does is...if you turn on the rcvr switch first....the servos are twitchy until the tx is turned on and the all is well.
BTW: This is with all the stock electronics JRXR3i, R135 and T/b is a JR 270.
Long winded I know...any intellegent help appreciated
Mr T
Mr T
