Novak millennium pro
ZANDOR
RCTalk VIP
Everson
I have this charger..
i am using the Nimh2 charging field.To charge a 5 cell sub C 6 volt battery..At 4.0 amps..
The problem iam having is that it is not fully charging my pack?
And the instructions are poop for this charger..
Some times when the batt is done charging it says 32mah and other times it says 130 or so mah?
So any one that has this charger that can help a brother out..
I have the older first generation of this charger, but have gotten this too when charging my reciever packs (5 cell nimh). Pretty much, the cause of the problem is a bad connection, or the cells were not fully discharged before charging.
If you have a tray, I would suggest putting them on a battery tray, such as Trinity's RealTime2 (or something like it). It will take each cell down to .2 volts (if memory serves, it might be a higher value).
Also, check your connectors for how tight they are.
You might also want to make sure the charge leads (from charger to pack being charged) are not coiled or looped. I dunno why, but this helps with my charger.
Heart B thanks for the info man..
It is my connection..Problem solved.
