omarinbenz23
Nitro won't pull fuel in-Clutch bell smoking
Hello,
I'm pretty new to R/C cars and this is my first and only car I have at the moment just using it as a starter to learn from. I have a redcat racing tornado s30. It has a sh .18 motor in it. I had ran the car about a year ago and my engine mounts weren't tight. So as I was driving I stripped my spur gear and my clutch is a little discolored. I had replaced the spur gear and left it away (never tried starting the car up when replaced). I forgot to put after run oil. When I tried to start it the car wouldn't Prime by covering the exhaust but it would Prime by covering the carb. It would also Prime when I would blow into the pressure pipe that goes into the exhaust. When I would put fuel into the carb directly the car would instant Rev up and shut down as it seems the engine wasn't pulling fuel in. I pulled the carb out and sprayed it with wd40. I replaced the exhaust gasket, re tightened the coupler. I replaced the fuel lines and checked for an air leak in the fuel tank. I also checked to see if my exhaust pipe was cracked or had a leak and that turned out to not have a leak either. I'm stuck. Car still won't pull fuel.
Any suggestions would be appreciated. Thank you for your time.
Hello,
