New to Mini's
Zachary
Gone - bye bye.
Well I just got a really nice RC18MT and just have a couple questions about the electronics. The motor is a Reedy mini-max modified motor with a Novak SPY ESC. How many turn is the motor and how good is the ESC/motor combo? I also got four batterys, Stock, One i don't know the name of but is a 1100mah NiMh, a Reedy VMX concept R-14 1400 mAh Ni-Mh, and also a supercharge team orion 1600 Ni-Mh. Everything else is stock. What kind of stuff should i get for it? Anything I should expect? Also whats a good Quick charger for it? Also what parts are the same/different as the other rc18 cars/trucks?
the reedy's are decent motors. I believe it is a 19T motor. Novak makes good stuff so i wouldn't worry about the esc. I ran the XRS and it was great. The reedy VMX battery is another item i have used and i would also recomend it. You can squeeze a 7 cell setup into that setup and it certainly perks it up. I got mine from maxamps. First on the list should be MIP super diffs and cvd's
I'm going to add this link to my signature since I've recommended it so much...
http://aedownloads.com/pdf/convert_ae18.pdf
Basically all RC18 are the same platform, the RC18r differs from the arms out. They all share the same chassis. Your main noticeable differences will be the body/wheels/tires/and suspension towers.
Thanks a lot. That really helps. :second_place:
