RColdschoolrc
- Racing
Hello everyone!!
I'm TOTALLY new to nitro, but I've been into electric R/Cs since 1983.
I'm at well over 150 R/C models over those 31 years.
I recently stumbled across a highly used/partly neglected Savage 25 with everything(and I mean 2 banana boxes of EVERYTHING) necessary to run it, PLUS tons of extra stuff, except the 8 AA batteries for the transmitter.
It even came with the new differential that it needed to have installed!
All for the sum of: Fishing it out of the dude's dumpster...
Though I didn't like the look of the pinion gear that the new diff was mating to, so I bought a #86031 pinion for $13!
I cleaned the built up nitro/dirt mix from the engine for 4 hours and the rest of the truck for another 2.5 hours.....
It has a Dynamite Mach 28 that sounds real deep and throaty.
So far it makes a stupid amount of power!!
The info for my "question" is:
When I researched the engine specs it recommends 2 turns out on the low speed and 3.5 turns out for the high speed settings on the carb.
That seems a little lean to me.(But what do I know? LOL)
I subscribe to the "Plugs are cheaper than pistons" theory, so I want it a little more rich than "normal".
When I checked where the P.O. had it set, the low was out 3.75 turns and the high was out 4.25 turns.
This seems possibly a little too rich?
Or is this where I may well want to run it to keep it rich?
I ran it for the first time today.
I only ran about 6oz of fuel through it before the receiver batteries decided they were tired(sat for almost 2 years) after about 45 min.
I think I'm at around 2.5 turns out on the low and just under 4 turns out on the high.
It idles high enough to engage the clutch despite a minimal throttle opening at idle setting, and kept dying when dropping off the throttle for moderate braking.
I will have to run at a less dusty location than today in order to actually see what's coming out of the pipe....
Any advice will help.
Thanks!!
Thanks!!
