circusfreak
Hey guys,
I have the original Maxx .15 truck that I recently upgraded to the OS .18 CVRX engine. The engine starts great and seems to have good top end. I am running the Robinson steel spur which I think is the same as the stock at 72T. Last night I chewed up the stock clutch bell which is a 20T. I am running O'Donnell 20% nitro fuel. I am about 10 tanks into this engine so far.
Couple of questions for you:
- I was expecting more low end out of this engine...maybe it needs more tuning, but it doesn't even come close to wanting to wheelie at all. Should it be more punchy?
- Since I went from the TRX .15 to the OS .18, should I drop a couple teeth when I get a new clutch bell? Maybe go with an 18T?
- Dude at the hobby store said I should have a little looser mesh since I have the steel spur, is this true? Maybe I should double up the "paper set" mesh?
- If I chewed up the clutch bell really bad (about 1/2 the teeth are bent over), does that mean that I have the slipper too tight, or need the smaller tooth clutch bell? Or just need a hardened bell?
Thanks for the info folks!
Rob
Rob
