If you like the SCX10 TR then you might also like the SCX10 Honcho
Axial SCX10™ w/Trail Honcho Body™
TR: Trail Ready™, 1/10th Scale | Electric | 4X4 Truck
SCX10™ w/TRAIL HONCHO™ BODY
The latest SCX10™ is inspired by off-road vehicles that are basically part truck and part buggy, nicknamed "truggies". The new Axial SCX10™ is the kit to have when it comes to having a realistic looking truggy. Scale features such as the steel c-channel ladder frame, plastic molded cage, and plastic front bumper with aluminum skid plates are included in this kit. These are just a few of the features that set this kit apart. WHAT IS THE SCX10™
The SCX10™ was designed to resemble its full sized "scale/1:1" counterparts, yet is still able to perform and crawl like a 2.2 AX10 Scorpion™ competition crawler. Unlike the AX10™ which is purely competition driven, the SCX10™ doesn't compromise its look for pure performance although the SCX10™ is a more than capable trail rig on or off the trail. SCX10™ vs. AX10 SCORPION™
The SCX10™ uses the same ultra durable transmission and axles as the AX10 Scorpion, but is built around a more realistic or “scale” frame. It also runs smaller, more realistic looking wheels and tires. These trucks are designed to have fun with especially if you have a few friends that have scale rigs. Getting a few guys together and going out for a scale trail run is one of the best things you can do if you're an avid off-roading enthusiast.
WHAT IS TRAIL READY?™ Exactly what it sounds like. This rig is designed to take-on some of the toughest terrain on or off the trail because it comes fully equipped with all the neccessary hardware. All you need are batteries and you’re ready to attack the trails or blaze your own. GALLERY
FEATURES: FULLY EQUIPPED
NOTE: Actual hardware may differ from product shots. e.g. Some product shots shown with OPTIONAL aluminum links and phillips hardware.
TORSIONAL STIFFNESS • Realistic looking frame
and cross braces improve
chassis rigidity
COMPOSITE PLASTIC LINKS AND SKID PLATE • Molded skid plate significantly reduces
hang-ups on terrain
• Durable composite plastic links are designed to absorb and flex under extreme conditions. Flexing helps to take the punishment of repeated falls onto even the rockiest of terrain.
SHOCK HOOPS • Allow for multiple shock
positions for tunable
performance
COILOVER SHOCKS • Dual Rate Springs: provide maximum off-road performance.
• Oil filled coilover shocks.
ADJ. BODY POSTS • Accommodates varying body sizes
• Includes additional rear mount for SUV body’s
BATTERY TRAY • Multiple mounting positions for adjusting weight bias. This allows you to adjust your suspension for different handling characteristics.
ELECTRONICS BOX • Designed to protect electronics from some serious off-road dust and debris
STEEL C-CHANNEL FRAME • Steel C-channel frame provides realistic looks, and it also delivers a solid rigid platform for some rigorous off-roading.
SLIPPER CLUTCH • Allows the motor to work more efficiently and greatly enhances the durability of the drivetrain allowing the transmission to slip in hard binds.
AXLES • Proven durability. Comes standard with a hi-tolerance sintered diff lock and hardened axle shafts.
TRANSMISSION • The transmission was designed to place the weight of the motor as low as possible to maintain a low CG (Center of Gravity). The ultra compact transmission doesn't compromise performance because it also allows for a wide range of gearing choices.
BONUS: LIGHTING • Take your scale build to the next level with the added bonus of 14 inlcuded light buckets! (7 different styles. LED’S not included).
• Light buckets hold 5mm and 3mm lights.
• Comes with realistic plastic lens.
ROCK SLIDERS • Rock sliders reduce body damage and allows you to slide off rock obstacles.
MOLDED CAGE/LEXAN FLAT-BED • Realistic triangulated plastic molded roll cage also comes with a lexan formed flat-bed with diamond plating and molded fuel cell details.
PRO-LINE® FLATIRONS® TIRES • Big slats of slanted rock – this is typically what is referred to as Flat Iron. In the case of the Flat Iron tire, it is made to do just that – traverse, descend, and ascend big slats of slanted rock.
8 HOLE BEADLOCK WHEELS • 8 hole beadlocks offer a realistic scale look. The wheel is made of a strong durable composite material, and comes standard with a grey aluminum beadlock ring.
TUBE BUMPER • Molded composite tube bumper is strong and durable.
• Realistic bolt on aluminum skid plates complete the realistic look
27T MOTOR • Tear up the terrain indoor or outdoors.
• Easy Operation: No Tuning, No Fuel, No Loud Exhaust Noise. Just Plug'n'go! (batteries not included)
ESC (ELECTRONIC SPEED CONTROLLER) • Forward and reverse speed controller.
TRANSMITTER • AM 2 channel pistol grip radio.
• Servo reversing switches for steering and throttle.
• Trim dials for fine tuning steering and throttle centers
• Your choice of 4 different frequencies allows you to do trail runs with your friends.
• Battery indicator light lets you know when your transmitter batteries run low.
NOTE: Some images shown with Optional Parts which are not included. Bodies also not pre-painted. SCX10™ MODEL COMPARISON MODEL COMPARISON Clicking on the images take you to the prospective pages.
Key Features SCX10™ w/CF100™ Body (KIT) SCX10™ w/Trail Honcho™ Body (KIT) SCX10™ w/Dingo Body™ (TR) SCX10™ w/Trail Honcho™ Body (TR)
PART NUMBER: AX90007 AX90014 AX90012 AX90016 Motor n/a n/a 27t 27t Links Aluminum Aluminum Composite Plastic Composite Plastic Wheelbase 11.4" 12.3" 11.4" 12.3" Sintered Diff Locker yes yes yes yes Rock Sliders n/a yes yes yes Bumpers n/a Front only: tube style plastic bumper w/aluminum skid plates Front and Rear Plastic bumper Front only: tube style plastic bumper w/aluminum skid plates Body: Clear/Painted CF-100™/clear Trail Honcho™/clear Dingo™/pre-painted Trail Honcho™/OD Green Spare (5th) Wheel/Tire n/a yes yes yes Wheels 1.9, Chrome 8 hole, w/green beadlock 1.9, 8 Chrome hole, w/grey beadlock 1.9, 8 Chrome hole, w/grey beadlock 1.9, 8 Chrome hole, w/grey beadlock Tires 1.9 Pro-line® Flatirons® 1.9 Pro-line® Flatirons® 1.9 Pro-line® Flatirons® 1.9 Pro-line® Flatirons® 4-Link Truss n/a n/a yes (not installed) yes (not installed) Lighting n/a BONUS: 14 light buckets
(LED's not included) 2 light buckets, 4 white LED's, 2 red LED's 2 light buckets, 4 white LED's, 2 red LED's Hardware Mixed Hardware All Hex Hardware Mixed Hardware All Hex Hardware OVERVIEW SPECS CHASSIS Wheelbase: 313mm (12.3") Width: 227mm (9") Height: 150mm (5.9") Ground Clearance: 68mm (2.7") Weight: 1814g (4.0 lbs") BODY Length: 457mm (18") Width without fender flares 216mm (8.5") Height: 137mm (5.4") ELECTRONICS Radio: 2 channel Servos: 1 hi-torque metal gear (standard size) ESC: forward and reverse ESC Motor: 27T 540/550 size Lighting: Simple LED controller: 2 white LED's, 2 red LED's. REQUIRED ITEMS (NOT INCLUDED) Battery: (1) 7.2v Stick Pack Transmitter Battery: (8) AA size batteries OPTIONAL EQUIPMENT CHASSIS AX30525
SCX10 Frame Set SHOCKS AX30090
61-90mm Aluminum Shock Set - 7mm Piston (2pcs) AX30114
Hard Anodized Aluminum Shock Reservoir (2pcs) AX30115
Hard Anodized Aluminum Pre-load collar (2pcs) AX30117
Hard Anodized Aluminum Shock Body 10x38mm (2pcs) SPRINGS AX30200
Spring 12.5x20mm 3.6 lbs/in - Super Soft (Red) - (2pcs) AX30201
Spring 12.5x20mm 4.32 lbs/in - Soft (White) - (2pcs) AX30202
Spring 12.5x20mm 5.44 lbs/in - Medium (Green) - (2pcs) AX30203
Spring 12.5x20mm 6.53 lbs/in - Firm (Yellow) - (2pcs) AX30204
Spring 12.5x20mm 7.95 lbs/in- Super Firm (Blue) - (2pcs) AX30205
Spring 12.5x40mm 2.7 lbs/in - Super Soft (Red) - (2pcs) AX30206
Spring 12.5x40mm 3.6 lbs/in - Soft (White) - (2pcs) AX30207
Spring 12.5x40mm 4.08 lbs/in - Medium (Green) - (2pcs) AX30208
Spring 12.5x40mm 5.44 lbs/in - Firm (Yellow) - (2pcs) AX30209
Spring 12.5x40mm 6.81 lbs/in- Super Firm (Blue) - (2pcs)
Part #
EAN
Description
Price
MSRP
AX90016 877493008314 Axial SCX10 - 1/10th scale electric 4WD truck -
TR w/Trail Honcho Body $585.00 $299.00
Parts List
Instructions AX90016 - SCX10 w/Trail Honcho Body TR - Parts List AX90016 - SCX10 w/Trail Honcho Body TR - Instructions (8MB) Questions? E-mail
[email protected] or call 949-600-8642
site map |
privacy policy |
terms of use
