Need new carb
jman214
Just received a free used sh.28 engine but it came with out a carb what will be a good replacement carb? If there a certain one I should get or it doesn't matter
Most carbs from 21 to 28 interchange bodied,The best carb that I've ever had was an ae 28 size carb.!
Why ....Its a full bodied all aluminum carb With out composit crap ,an only has the two needle settings!
Its easy to tune an keeps a tune!:D
I haven't found that to be the case. Seems all my engines have different sized necks.
That said, I think the SH engines use similar stuff that dynamite engines use, so perhaps a losi/dynamite carb will work.
https://www.rcplanet.com/Redcat_Racing_Sh_28_Carburetor_p/redte2809.htm
Not sure I'd spend $60 on just the carb since you can buy the whole engine for around $100 on ebay.
Not sure if one of these will fit:
http://www.ebay.com/itm/Losi-8mm-Ca...270642?hash=item25a6535b32:g:U5AAAOSwBahVU4Da
SH engines used to be in a lot of XTM's stuff too back in the day. The old SH28 was a well regarded basher engine. I had one and it did ok in my savage, didn't hold it's pinch for a long time though. The newer ones don't last all that long either. After 3-4 gallons, mine became pretty tough to keep running due to lack of pinch.
