Need help finding 1/10 th scale 13" wheels.
johnbhm
I haven't been able to get to my work bench for months but that should be changing. In the meantime I have been come up with the idea for my next project. Several years ago I completely rebuilt a 50's airstream bambi. It was to be used as an executive meeting room but ended up being a very expensive garden shed. My plan is to build a 1/10th scale trailer to pull behind my crawler. I have access to the original for all my dimensions and have been working on my aluminum panels but haven't been able to find the wheels tires build the chassis. They were 13" but 14" are a common upgrade. I would like to be able to find a complete axle and springs but everything I am finding is to big. Thanks for any help, John.
The closest you are going to get more than likely is 1.55 wheels. Where are you located? Can you post some pics of your actual wheels? I could possibly design and 3d print some for you. But finding the tires will be the difficult bit unless you have those 3d printed as well.
Besides those, rc4wd had a 1.3 michelin tires on the 1/14 construction trailer.
https://store.rc4wd.com/Semi-Truck-and-Trailer_c_153.html
https://rc4wd.com/go/rc4wd-tire-finder/
If those dont work, lesu and rc4wd make rc forklifts and trailers.
13 " 1/10 scale nothing like that in the 1/10 scale line. now is this outside diameter or rim size?. maybe a hardware store a wheel barrow wheel...
I'm thinking he meant the original wheels on the 1:1 trailer were 13 or 14 inches? That would probably make more sense.
so 1.3 to 1.4 " rims in 1/10 scale sounds more like 1/18 scale had some shores on a 1/12 scale .
Thanks for the suggestions, I think I found something that will work. They are 1/12th scale 1.3" that resemble generic stamped steel wheels with tires. Thanks again , I was stuck on 1/10th scale and was going in circles and not getting anywhere.
Can you share what you found?
https://www.amazon.com/ller76-4pcs-Wheel-Install-Tires/dp/B08KGMYGQC They are cheap and a little wider than I wanted but they have the general look that I want which is more important as they will be painted and tucked under the trailer. I am still looking but this gives me something to start with. I do like the 1.3 Michelin tires but can't find wheels that I like. Thanks again, John
Know anybody with a 3d printer? I have printed lots of wheels. It's not hard. I printed these for 1/16 scale.
My kids have a couple of 3d printers and will try that route next but am going to look at these first. Painted with chrome center caps the wheels should have the perfect look its the tire that I am unsure of but will see how they turn out.
