Need advice for Savage parts
Sgt Blamo
I've decided to buy an SS kit and would greatly appriciate any advice or recommendations as to what radio, servos and other general items that are needed, and/or recommended. Sources to purchase, or websites that you like with part numbers would be gret too.
I'm working on aquiring LST shocks, a .28 Fantom w/ steel pipe, HPI cam steering & throttle mod, diff gears(would like a spooled rear, w/ a LS front), 5 or 6 cell re-chargeable hump pack, SS disc brake set.
I will be ordering an extended (1.5") and lowered CG chasis w/ extended dogbone. I was thinking of running the LST tires & wheels. I am looking for wheel spacers(1") to widen it.
Anything you may think I've overlooked, or don't advise, please let me know.
Thanks
PS.
Feel free to email me @ [email protected]
Do some research, as the LST shocks have some issues with the rod ends and shafts. I have seen the shocks and even though they are HUGE, I have seen them break on stuff that a Savage takes easily. Look at the UE shocks. THey are pricey but worth their price when you run em.
Jon
Yea thats what I run and I love them.. Still love the bead lock X75's the best but the wide offset rims (.75" rpm I think) really help ... I only have wide ofset rims. But I would NOT you the spacers... I think its askig for desaster.. but they are worth atry.. If they were indestructable I would use them on a lot of rims that I like that arent wide offset.
Skip,
Who makes the X75 Beadlocks ? I thought they looked great and would love to get a set. i wonder if they would fit my Revo, same hub as the T-Maxx.
should fit every maxx sized hex..
Maximizer makes em.. They are slightly heavyer, and some tires pop beads and some dont.. stock tires for insatnce.. pop way easy. LSTs never.
I have the Trinity low roll foams in my stock tires and haven't popped a bead. I wonder if the harder foam helps by keeping the sidewall flex to a minimum?
I was running that too.. thats odd. I know others that found the stockers to pop.. I mean I got used to it and used them, but you knew on a tumble that one tire needed matianence.. Then the LST tires, which are very soft, still havent needed to be re-mounted.
Maybe I am just lucky, I have also heard others who have the bead popping problem with the stockers or other soft tires. I'm sure there has a small margin of user error in torqueing the screws down, they were a pain in @$%^& to get in, so I tried to make sure they were nice and tight.
Of course, now that I've said this my beads will probably pop tommorow....lol
Yea there is definatly a technique to getting the screws going. I do get better every time but there is always a naughty word in there at some point...
I hope your luck continues with the stockers as I like them tires.
Bought a NIB RTR . I wanted another truck to play with our Revo's (I've got 4 "Chilens"), so I bought the RTR today and have a new SS28 on order, should have it in a month or less.
I figured I would break it in stock, Then I'm installing a few mods, such as breaks, HPI steering,better servos, a decent pipe,extended and lowered chasis and some beadlock wheels w/ LST tires.
I just bought a nice NiMHD battery back w/ quick charger for it. I also bought 4 LST shocks NIB to install.
Skip,
Didn't you say that you had to change the shock towers to mount the LST shocks? If so, I would love to know what you advise and were I can aquire same.
I will post pics shortly, once I begin construction. I do have a few decent small AVI's of the Revo's and Savage jumping together, not sure how I can post it or where.
See Ya!
Vey nice, you will probably one of the first to have the new SS kit. Make sure you write up a review for us!
Congrats again on your purchase!
I've got a question about breaking in the .25 motor in the Savage. They state that you're supposeed to let it idle thru the 1st tank? That will take fo-eva! So far I've just done some basic heat cycling like I used to break in my 2 stroke Pilot motors.
1: Fire it up, idle for about 5-7 M, then shut down for complete cooling.
2:Repeat same, except I slowly rev it up and down to 1/4-1/2 throttle for about 10-15 M.
Repeat same again with total cool down between (same is on two blocks, so tires are off the ground).
Next step will be to drive it @ 1/4-1/2, then 3/4, cool down.
Then lean just enough to be able to hit full throttle with out it bogging.
Does that sound acceptable?
Heat cycling is a good way to break in an engine as long as you are reaching minimum temps which I think is 200 F. I think your method is sound.
