brushless12v
- Wyoming
- Racing
- Scale Builder
- Thread starter
- #41
I got to looking closer and there's really minimal wear on the gears..
Wow! thanks for digging that up! I think you are dead on those parts look identical to hpi, nice investigation, looks like good upgrade metal components, thankyou very much.Not with that attitude!
That looks similar to the hpi e10 diffs.
https://www.hpiracing.com/en/parts/109291/std
Will do, I'm not a heavy thrasher/basher, especially, as you guy's know, when you've put in a lot of time in to improve or build your rig it's all for not if you're tearing it up, of course I will see where it's limits are and as you , keep it clean, I couldn't imagine getting one of your guy's high dollar rigs messed-up. and thanksLet me make one suggestion... clean your truck!
Its a good idea to clean down your truck after every run.
You get all the muck off and can inspect everything for damage, loose etc..
More importantly, when you pull apart your diff ( or whatever you're fixing) you won't get bits of lawn and sand in in there too.![]()
Your rc might not be super high priced but it still needs to be looked after and maintained.Will do, I'm not a heavy thrasher/basher, especially, as you guy's know, when you've put in a lot of time in to improve or build your rig it's all for not if you're tearing it up, of course I will see where it's limits are and as you , keep it clean, I couldn't imagine getting one of your guy's high dollar rigs messed-up. and thanks.
I think a cover like that might be helpful under a body but you'll prob want to be thinking about a full lexan body for better debris protection but prob more important is for roll over damage.Right on! here is my redcat with a simple cover I made for it, so hopefully I can keep it clean, it's open front and back to promote air flow and with spring/summer around the corner my electronics have fan and heatsinks on them to help cool trying to keep them under 170 deg.
Yes sir, will do.Give that cover some black paint so it can't be seen under the body now that its lifted.![]()
That T4 is a nice ESC!!!Can you say Frankenstein???
well after a couple different esc combos and pinion changes, I got it runnin' out fairly smooth, guess I'll tidy up my mess replace some wheel bearings and shim a few spots to true up the steering and wheel camber and ol meteor will be okay for light track and trail use.
