I'm with both of you. I have read several articles on the reasons not to super charge or turbo a nitro engine. Here's what I gather, maybe somone can tell me if I got this right.
From what I hear, and have read (not that I know much), a supercharger, or a turbo try to do the same thing. Compress the air before it goes into the cylinder(more air in same space). This means with more air in the same place, you can add fuel. More fuel, and more air in one space means a bigger explosion in the cylinder. The bigger explosion means more power.
Here's the problems with a true Turbo/supercharger setup on a nitro rig.
#1 the exhaust port on a nitro engine is open during the intake stroke. When you try to stuff more air in, instead of compressing the fuel air mixture, it all blows out the exhaust before it explodes. (on a regular car the valves are closed so compression can take place). THe intake actually closes before the exhaust port. So anything compressed IS going to be blown out the exhaust during an after the intake port closes. There's no way to compress air if you don't have a semi-air tight place to compress it
#2 There is really no way to add fuel on the fly without a very complicated computer, or some mechanical contraption that is throttle activated. If you dont add fuel when the turbo/supercharger is spooled up (at least 1/4 throttle), then there will be more air in the cyclinder, hence a lean condition. Lean for nitros spells heat, and lack of lubrication.
#3 To add fuel without a high dollar contraption, you will have to run the engine very rich. This will be fine for mid to high throttle when your super/turbo charger spools up and is feeding air, BUT when you are trying to get off idle power and are low in the RPM range, you will be to rich for adequate power.
#4 The drag weight/rotating mass. The nitro motor is going to have to physically spin up the supercharger. This adds to the rotating mass you need to get moving in order to get to a good rpm range, its going to killl your low end. To run it right, you're already going to have to be running rich as all hell. Rich + added weight = even worse accel.
#5 Turbo restriction. To setup a turbo you're going to need to gt past all of the problems above cept' #4. What you are going to have to get past with a turbo is the exhaust restriction. Exhaust is a really big deal for nitro rigs. Restricting the exhaust is just plain and sim0ple not a good idea. How long does it take for your nitro to die when you plug the exhaust? They also use the exhaust on smaller engines as a type of throttle, the more you restrict the exhaust, the slower it runs.
So, there you have it. I may have it off a little, but i think the concept is there. For the little bit of performance you are gaining, you are losing that much in exhaust drag, and spool up inertia.
Not only that, if you have your low end power, your running dangerously lean in the mid to upper end. If you are not runing lean, your accell is going to take it in the rear.
I'm thinking if you have the old T-maxx with .15, for the 169.99 hey are chargin' you could pick your self up a hell of a motor. Not just a .15 but you could go with a xtm .18 or any other high performance motor. You are better off with a bigger displacment motor than you are a supercharged little one. You will have more torque.
If your looking for power with the same motor you have, you can port it yourself, or send it off to be ported for less than the supercharger.
If you are loking for serious "I Spent a lot of money on my maxx bling", and lots of "super shiny, one of a kind " the supercharger is for you.
If you're looking for real world performance I just don;t think is going to be there.
BTW I see the draw, supercharged, and turbo motors for 1/1 cars add a lot of power, with minimal modifcations. Lots bolt right on, they are expensive but don't always require internal mods, and the power addition is sometimes unbelivable.
This is just what I gathered from rstudying about forced induction on 2 stroker nitros, please correct me if I am wrong, and feel free to add anything I missed. I'm afterall a nitro
:n00bie:
