- Central Florida
- Racing
- Thread starter
- #101
Update!!!!
Ok, you guys asked for an update, well here it is.
Money has been a little tight with the holidays having passed, and having to move again, so time and toy money have been at a premium, but work still progresses, just slower, lol.
I got a set of Axial AX10 axles for Christmas from my boys, I got those built and I have started working on making the links which will be made of 1/4 inch solid aluminum rod drilled and tapped for the ends, no all thread here.
I have also done a bit or work on the interior. I have been working on the firewall and dash, as well as a back wall. It is all made from styrene with diamond plate styrene glued to it and the painted silver. The oh poop handle was a leftover piece of the tree from the axles. The steering wheel center is made from a servo horn and 1/4 styrene tube. I still need to make the wheel itself. The white part of the dash is still unfinished and will eventually be black.
I have also begun work on a windshield mounted light bar, the clod lights are just temporary until I finish it then I will be using a high lift light bar set.
While bored and broke one eveing I decided to mess around with some stuff I had laying around and made up some small scale bungee cords for it.
And finally I have saved the best for last! The most important thing I have been working on at the moment for it. A set of 2.2 5 hole aluminum beadlocks. My good friend and new forum sponsor Joe from www.eastendmachining.com have been working on these. They will have twelve screws holding the beadlock rings on to the rim, but the screw pattern is such that any Axial 6 hole rings will also work on them giving me many options when it comes to the rings. This is just the first proto-type wheel, they still need to be finished but man these are the sweetest rims! Exactly what I was looking for! Thanks Joe!!!! I can't wait to get the full set!
That's about it for now.
