I think it might be a clutch related issue but i don’t know otherwise, any ideas?
Hi, thanks a lot for the help i taught through your ideas and the only one I can see making sense for me is that it might be tuned to lean.Do the wheels stop turning in the air while it's at idle? When you say it won't rev, does the throttle still open, but the engine bogs down instead of moving the car? It's not exactly clear what situation you're describing, a video might help.
It could be tuned too lean so that it's stalling with any resistance, the clutch spring could be broken so that it's always engaged, or something in the diffs could be loose that allows them to freewheel but lock up when power is applied.
To be honest I had the car not start for a month a while ago and had bought a new piston and sleeve it’s starting now and I went trough the brake In procedure. And haven’t got it tuned at all till now, so I’m not sure
I started it up and got the idle down today here I attached some photos maybe they’ll help I’m not sure how to upload vids so here a link to the vid: https://vm.tiktok.com/ZGJHKrsq4/
Hooe this helps
yeah you kindoff have a point that the engine idnt as snappy as it used to be checkThat engine doesn't sound too happy, kind of struggling. It should be snappier when you hit the throttle. I see the oil spot from the exhaust, that's encouraging, but there should be a little more smoke when you rev it. I'd richen up the high speed needle.
It does look like the clutch is constantly engaged, you might need to replace that o-ring that pulls it inwards.
My tiktok and you should find a couple of vids on how it used to respond.
Abput the o-ring I'm thinking of replacing it with this
Hi, well it might seem that way but that is because the tyres are un-evenIt looks like the problem is in your differentials, I can only see one side of the wheels spin.
The aftermarket clutch may not fit well and you may have to adjust the engine and move it backwards.
Thanks for thw clutch option, il probably order one for that cheap and il just have to paint for it from china.Those are pretty good, I use them in my nitros. Might as well get a plain one because the anodizing wears off pretty much immediately, and will only wear away the clutch bell a bit. Here's a cheaper listing for them.
Thanks for admiring my TGXThat's a pretty nice, vintage Tamiya TGX!
Buy if you have seen the vids it doesn't really make senxe to me that underload it doesn't rev so it may not be the clutch
It used to stall but I had fixed that should tune it and try againIt could be several things at once. The wheels should stop entirely when it's at idle, and they never stop turning. That suggests the clutch is rubbing. These engines don't produce much torque at idle, so it's struggling to pick up speed when you open the throttle. Normally they can rev up a bit, the clutch engages, and then they start moving, but if the clutch is rubbing, it'll already have resistance on it when you open the throttle.
If you pull the brake, does the engine stall?
Have you checked your idle needle? My NR (Nitro Rustler) used to non-stop spin the tires even on the ground. I just had to close it a bit and then make sure that when you have full brakes the carb slide or whatever it's called doesn't move. That will at least rule out 1 issue. From what I have seen, you want the gap to be about the width of a credit card.It used to stall but I had fixed that should tune it and try again
Hey well I took your thaught on the matter into account and I striped the motor of the chassis and inspected the drivetrain.It could be several things at once. The wheels should stop entirely when it's at idle, and they never stop turning. That suggests the clutch is rubbing. These engines don't produce much torque at idle, so it's struggling to pick up speed when you open the throttle. Normally they can rev up a bit, the clutch engages, and then they start moving, but if the clutch is rubbing, it'll already have resistance on it when you open the throttle.
Hey thanks for all the help, well basically rlly good news, I freed up the drivetrain and tuned the car so when I brake it doesn’t stall and got that down perfect and now that I have other wheels on it not seizing the drivetrain anymore therefore it buyer smooth.It could be several things at once. The wheels should stop entirely when it's at idle, and they never stop turning. That suggests the clutch is rubbing. These engines don't produce much torque at idle, so it's struggling to pick up speed when you open the throttle. Normally they can rev up a bit, the clutch engages, and then they start moving, but if the clutch is rubbing, it'll already have resistance on it when you open the throttle.
