My aftershock with RPM and other things.
olds97_lss
RCTalk VIP
Dekalb, IL
Just thought I'd post the progress of my Aftershock. I've only run about 1/2 gallon through it so far, but the second quart was pretty fun. Breaking in the Mach 26SS was a nightmare. One of the worst break-ins I've ever done. I believe I had a fuel delivery problem and didn't know it. Over the past two weeks (been cold and rainy/snowy out) I haven't driven the AS, but my eBay orders have been showing up.
So far it has RPM arms, RPM gear cover, 1400Mah receiver pack, airtronics receiver (for my MX3), 14mm savage hex's, HPI polished tuned pipe, 3mm metric cap head/countersunk screws for everything but the trans, the trans gear switch mod (higher top end) and of course, a homemade roll bar.
Replacing the arms was a mild pain, but only because I haven't worked on the AS yet. The fuel delivery problem that made break-in a total pain was a leaky fuel filter. At first it was loose and dumped fuel all over the truck. Then I tightened it, got it running had have run about 1/2 gallon through it. As I was cleaning it, I noticed a large amount of residue around the fuel filter still (a week later). Then I noticed when I tightened it, the o-ring came out and was pinched causing it to still leak. I replaced the entire filter with a spare I had.
Anyway, here's my truck with all the stuff on it. You may laugh if you like, but the roll bars I make tend to make bashing less bothersome. My revo and savage both hold up really well due to the roll bars.
Some of you will be surprised to see a whole body and the absence of hose clamps ;)
I went kind of tall with the roll bar, but this allows the body to almost rest on them. That way when it lands on it's roof, the body won't flex so much and be so likely to crack. The body won't go any lower due to how it's mounted on the truck, so I had to deal with it.
I had issues with the RPM gear cover rubbing on the back of the spur gears. I drilled a hole in the back of the gear guard and into the chassis/frame rail, then screwed in a self tapping screw. This makes the guard stand more perpendicular to the gears and it no longer rubs. It rubbed quite a bit and I would have been afraid to run it due to excess drag and melting gears.
I have a full body in the closet for the revo... except it was for a 2.5 revo and not a 3.3 chassis revo. It will get wacked at some point I'm sure.
I kind of like having a full body. Looks less hill-billy...
The gears melting to the RPM gear cover has happened. I could probably dig up some photos on another site for ya.
looks good. Always nice to see a "virgin" truck.
I'm glad I changed it. I hope the screw stays in place and keeps it from dragging. Right after I bought it, I asked about it on a forum. I got 10 replies saying I should have bought the LST2 gear cover instead. It doesn't rub (or is less likely).
Dude, come clean ..... that's not your truck!
LOL
Olds your stuff is not pretty, but if anyone on this forum gives a true evaluation of the durability of a vehicle or it's hop-ups it you!!
You are the bash King and you make McGiever look like a sissy!! ALL HAIL!!
Nice ride man, I look forward to it's transformation.
Mr T
Actually, that's about all I'm going to do to it. I've bashed it for about a quart and it handles well, jumps well and just generally works well for what I want. I do have a set of LST2 shocks coming in the mail though... I don't think it's going to need much more tinkering like the maxx, savage and revo needed.
Anyone else have engine issues with the mach 26ss? Mine is/was leaky around the backplate. I've kind of been chasing my tail with the tune. One minute it's 220 and rich, then it's 280 and screaming. I can't find a happy medium.
I'm hoping the leaky backplate was my problem. I sealed it and the carb today. I'll see what it does tomorrow.
BTW, the roll bar held up great! I had a couple wheelies at high speeds and not so nice landings. It took the brunt of the impact and sloughed it off. This things going to be fun.
Olds that is one sweet truck. Makes me want to start making roll bars to. Just simply bitchen. Hope you get the mill tuned up though, sounds like my 2.5 well same problems.
Bryson
Well, I had my first casualty today. One of the RPM upper arm links (the threaded metal thing) busted... Too bad RPM doesn't make just a solid arm that isn't adjustable.
Anyone know of really tough links that I could use in place of the ones RPM uses?
MPI dosent make any, I thought they made all that kind of stuff.
Bryson
