MT2 help needed for my rear axle outdrives!
Throttle
East Aurora, NY
Never mind. I'm closing this thread. I finally had time to sit and check out what was wrong. Thanks anyway.
Is the drive cup shimmed?Is it the stock cup?
The shocks were mounted on an extra hole about half way up the arm. They should be mounted at the end of the arm, inside the rim. They go on the end on the arm mounted on the end pin with a washer and E-clip. He used extra shims to fill in the void on the pin. I looked in the mt2 manual that I downloaded. It looked correct because of the three holes in the middle of the arm but it wasn't so. All is well. Thanks for the reply Jon2.
