- UK, wettest place on earth
- Crawling
So, having acquired a new motor for my latest project and making/taking many measurements, I've still ended up with a shaft that's too long..
Motor in question has an 8mm shaft, 30mm in length, I need it 5-6mm shorter, also needs the flat spot made longer.
My question is this,
What's the best method to cut the shaft and add a flat spot, I'm concerned about heat, (I know I could do this with an angle grinder) but this is a brand new motor and cost me too much to screw it up..!!
Whatever method I use I think I may need to buy tools to do it, so want to buy the correct tools once..
