Originally posted by SkyMaxx
You guys crack me up.
If the carrier rolls too far, anything that is not tied/chained down that has sufficient mass to overcome friction between it and the flight deck will fall into the sea.
No, the roof does not fall into the ocean. And no, the carrier won't sink. A fully loaded carrier has a huge amount of ballast (called fuel and ordnance) in the belly of the ship. This weight tends to make the carrier act like a weeble wobble. Yes, it will rock and roll, but it would take a fair amount of force to actually capsize a carrier.
If a real torpedo were fired at the carrier, and she couldn't avoid it by turning or out running it or any of the other methods they use to protect against torpedoes...she would take a hit. Depending on where the hit happens, the damage would and could be very minimal. But it could also be very catastrophic.
As for cutting the rudder over too far, the ship would continue in its turn until it reached an equilibrium point and then settled back into the water due to loss of forward momentum. When the ship makes these hard turns, she bleeds off speed like crazy.
Originally posted by Çh®i§tiªñ
So are you telling me the flight deck of an aircraft carrier doesn't come off in an excessive turn to prevent a capsize from happening?
