wacmartin
DAMN TREES
I got a problem and I need help. I installed my aluminum front spindles, front and rear threaded axles, bearings, and aluminum oil filled shock all losi products on my micro t last night. First I'd like to say that I personally think the shocks aren't very good, I put 32 1/2 weight oil in them pumped them to remove the air bubbles and didn't fill them up too much and I got no rebound after compression. That's not my big problem though, when I turn the servo turns the car but doesn't center again just makes noise like it's trying to center but can't and just keeps turning until I center it via the steering wheel on the TX. Even then if I don't do it perfect you can hearing it trying to center. I disconnected the steering even took the servo out and it turns fine and there's no labouring noise of it trying to find its center, so I know it's not the servo. Every thing is aligned properly, I noticed I got some damage to my c hub on one side could that cause it? Actually the axle on thatside is a little off because of the damage. Any help would be awesome, maybe I'm missing something I don't know.
