Fourthbean
You guys managed to help me get my sts 30 d30m started in a previous thread, we have been running the truck the past few days and although it was hard to start it had plenty of power and we always made sure there was blue smoke coming out (I hadn't gotten around to tuning the LSN yet).
Today it was being especially hard to start, I had taken out a shim from the head thinking it was only supposed to have one silver one in there (I pulled out one copper shim). (in afterthought I am not sure if this was correct or not).
I managed to get it started and was messing with the tune as I had goofed with the HSN getting it to start. There was almost always blue smoke coming out, however it seemed as the engine warmed up there was less of it (and I was richening it along the way). The power just wasn't there, I ran it down the field, braked, and then gunned it and the engine died. I brought it home to put the shim back in and see if that was the problem. After getting the head off I see that the glow plug is completely gone (no coil) and there are silver metal shavings about 1mm square in the combustion chamber. I continued to disassemble the engine and found more in the crankcase. I attempted to take some pictures but they are all blury.
There is a groove where the connecting rod moves around the crankcase and I can see where the rod has scraped on the side next to the bushing. I sprayed the engine out with carb cleaner and got the engine to rotate however somewhat clunky. When slowly turning it the correct way it will sometimes get caught where the connecting rod comes close to the crankcase on the downward stroke.
After explaining all of this it really seems stupid to ask if the engine is dead, as that does seem quite obvious.
Though I am curious what I did wrong! Will an air leak cause this? How many seconds of lean running does it take to destroy an engine?
Thanks for any help on avoiding this the next time I run an engine.
Hmm, it seems to be turning smoother now. Maybe there was still a piece of metal blocking something. It still has friction at TDC as if it still has pinch, however there are some nicks on the edge of the piston.
