ran out of file space lol. Going to continue in another post.
In this screenshot, it is extruded and is just the bottom chassis but longer and the front of it is slightly narrower. I need to make it even more narrow because currently it will not fit in between the front shock towers. The 200 mm dimension is just showing how long the top chassis plate will be.
In this screenshot, it shows that the unnecessary parts of the plate are removed.
View attachment 174925 In this screenshot, it shows the hole placement that lines up with the bottom chassis hole placement that connects the two together with a 30mm M4 spacer.
This photo shows that I need to move the front mounting holes back a couple of mm because the holes do not line up at all with the front bulkhead screw holes.
This photo shows where the hole placement for the bell cranks are. I also need to move these back a couple of mm because where they are now makes the bell cranks rub against the front bulkhead.
Thats all I have for now. If you have any questions or want the files, ask me and I will happily give you access to them
. They are almost done and I will also be designing a 3D printed battery mount for it and I will also release those files as well. Thanks for looking in!
