chuck3
http://www.horizonhobby.com/Products/Default.aspx?ProdID=LOSB5061
this is the pipe I'm running right now. same as the one neo showed in the pic above except mine is a diff. color. this sucker seems to work really well with the spec3 and sounds awsome! its pretty loud and seems gives the mill a little bit more to breath with. and the stinger is in sync with the bottom of the chassis to, so no more high centering on curbs and jumps! WOOHOO!
http://www.horizonhobby.com/Products/Default.aspx?ProdID=LOSB5062
this is the peice that came stock on the AS. as far as I'm concerned, the only thing it has going for it is that it looks indestructible. as i found out, its not. especially when the front brace arm for the pipe breaks and the pipe drills into the ground and props the truck up on 2 tires. needles to say, the header was shot and the pipe was crunched. so i was "forced" to upgrade.....shucks i guess
