Hey RCN!, Has anyone had to fuss with LST pipe quality?...
In other words, what is the dealio with the LST sport pipes? Are they pure garbage or what.
I planned on replacing the stock pipe anyway, but the pipe I got on my LST1 appears to be restricted, and not giving enough back pressure to the fuel tank.
I say this due to the fact that the engines odd tuning issues I'm having go away as soon as I apply some air pressure to the return line, manually that is.
It's not completely blocked, but it pushes no flow from the pipe when the engine is running.
This LST1 has had an engine upgrade from the original mach 26 to a mach 28.
I don't think that would be a relevant consern here, but just want to be through in this discription.
Until I go to a better pipe, I'm wondering if this pipe can be modded to opperate properly.
I susspect the flow issue is localized at the pressure outlet at the top of the pipe.
Because I'm still breaking-in the .28 with over-rich needle settings, this adds to this issue by fuel oils collecting and getting in the return line.
Any suggestions are welcomed and apprecieated. Thanks all.
