LSN Problems
raaazzzeee
orlando
i have a duratrax 1/8th scale buggy i adjusted the LSN to try and obtain good performance when that didnt work i decided to start over reset the LSN to factory and it wouldnt even start after alot of tweaking the LSN i got it started once it warmed up i hade to keep feeding in throttle trim to keep it idling and the problem just kept getting worse until i was at almost half throttle to keep it running now it is sobad that a can hold wot and it wil tak 2-3 seconds to go also I've tried setting it to speed up for 2-3 seconds after piching of the fuel line and set like that it wont hardly start and it takes 20 puls to start it when its hot
Sounds lean to me.
I had an issue like this a few weeks back. I needed to back out the LSN almost 2 full turns from flush. Ran great after that.
thanx but i tried leaning riching and it doesn't even begin to help either way i turn it
I think it sounds like you Hsn is waaayyy to rich thats what i had a problem with. Set the low speed needle to stock and then lean the hsn up just a smig. Hope that helps a little.
Bryson
thanx for the tips it's close i will try again tommorow after my glow starter charges
