Note: This feature currently requires accessing the site using the built-in Safari browser.
What is a good carb to put on the big block Lrp .32If the carb "neck" is the same size, then yeah, it should work fine.
Is there a particular reason you don't want to use the stock carb? OS carbs are as nice as they come, you could try one of those, like an OS 21-J3, just off the top of google's results.What is a good carb to put on the big block Lrp .32
