nitrohuffer
ok. when I finally can get my AE .15 mills to run, she will only run with the glow igniter on. As soon as I take it off she dies. ALSO, I can see fuel spewing out of the bottom of the head. I took the head off and checked the shim, she looks fine...not bent, flat as a 10 yr old
So I checked the pinch of the sleeve and piston.. barely any at all. Slightly tight when it is all the way tdc. I put some high tach sealant on the head and seems fine. No leaks. after running the 10gt for a few (bout 3 tanks) there seems to zero pop to the mill. new motor time? or just a sleeve and piston?? thanks in advance guys!!
