Final prep work before cleaning.
I went around the entire profile with a drum sander on my Milwaukee, being very careful to only climb cut, where the drum is trying to pull you in one direction. Let it pull you. Never drive backwards unless you have to, as it can dig in.
Starting at the rear.
For the wheel openings I get it close, then come back with 220 grit and bring it in by hand. I don't like rough edges.
Got the rear of the truck done with my sanding stick and the 220.
Pretty smooth.
Front turned out pretty good. I use the long sanding stick here to keep it flat. The plastic film is kinda hanging out here, making it look like it's not perfect, but it is.
Almost done.
Here you can see the finished edge.
I go all the way around the outside, with the sanding stick, cutting an angle to slice the excess film off the outside. It has 180 grit on it. Then I go back with the folded 220 grit and do the inside and outside edges again, basically rounding the edges over.
After that is done I take some 400 grit and smooth things up a bit further. If you feel any sharp edges. Or any film hanging off the edge, you're not done.
