I started working on getting the rear axles, links, and carriers on. This simple process quickly turned into a two hour ordeal.
Before I got to that, I noticed I had missed the shock tower brace, so I installed that.
This shock tower is laminated between the trans case in the rear, and held there with a long screw going through a tab on the shock tower, then through the transmission, then the other shock tower tab, then through the metal motor plate. Then it has two screws in the front at the base of the shock tower. Then it has one going through the chassis into the bottom. Then this crazy X-brace. I have never seen a 1/10 plastic shock tower held in so well. This takes a bit of work to remove, obviously. This will be appreciated later.
From there I installed the carriers, and popped the inboard bearings into them. I went to put the bearings in the outer journals and the right side one was loose and would fall out if turned upside down. Grrr. I had already swapped that one with a spare one I had, so it turns out the spare was bad as well
So, I remove the e-clip, yank it out, and see what I could come up with. I found some replacements online, but I have to wait to order them.
In the meantime, I wanted to try something sillly. I laminated a strip of paper into the bearing journal with some CA, because it was really loose. This ridiculous shim idea actually worked
It's the craziest hack job I've ever done to an RC, and it was just so I can continue putting this kit together, but I actually wouldn't be scared to run it, and I think I will. The bearing is in there really snug
So I reinstalled the carrier and carriered on
I put the axles in, and went to attach the upper links, and noticed the camber was going to be way too far positive. Crap! I must have put the links in the wrong hole on the shock tower, even though I could see the holes that were used.
So, I had to remove the shock tower for like the 37th time to move the links, thinking I mounted them too far inboard. I moved them to the center hole and reinstalled the shock tower.
Then I found the camber to be better, but my axle pins didn't sit far enough into the outdrives
Upon looking at the original pic before teardown, the carriers needed to be mounted in the inboard hole location. DOH! Curse you Losi and your terrible exploded view!
So guess what had to happen? The e-clips on the carriers needed removed, then moved inboard, then the shock tower had to come out again so I could move the upper links back where they were. Uggh!
FINALLY - Problem solved.
Next up is the steering rack, which got me thinking... I haven't grabbed a servo for this yet
