Losi Tenacity Db Pro Problems
Blackjack8289
Ohio
My Tenacity Db pro has had some problems. On the first run, the top motor screw pulled out and stripped the threads. To fix that, i put in a longer screw. Next, my motor pinion came loose (my fault, didn't put on enough loctite). I put some more loctite on an waited 24 hours. Next few runs went fine but on the fourth run out, after about 20 minutes, the motor had either come loose, or the top screw stripped the motor threads again, and the spur gear had been stripped. If anyone else is having the same problems, or has a solution, please let me know. Thank you in advance
time to pull motor replace spur Id also do a new pinion.. either disassemble motor pull endbell and drill and tap it for new motor screws..change motor screws if you can I never linked pan head screws on a motor....
