sweetdiesel
aka SouRGassssssss
I picked up a HIGH Roller for my B-day as a backyard basher and here is my review and impressions. I'll be adding more info to the thread as I test it on different terrains and upgrades.
Out of the box: The truck feels well assembled. Checked all the screws and they were all tight. There is a lot of play in the knuckles and hub carriers, probably due to the soft plastic. The plastic of the arms also feels soft, I can twist them easily with my hands. Front and rear bumpers are thin and also have good flex. The main chassis is relatively stiff. There is mostly hex hardware with just a few Philips screws to secure the weak feeling steering servo. The servo saver is a nice unit, built into the steering bell crank similar to 4WD buggies and TCs. Unfortunately, the hinge pins still use e-clips. The aluminum shocks are very nice for a budget truck, and feel smooth when pumped. The stock ESC is rated down to 12 turn brushed motors and is a very compact unit. The stock motor is a 12 turn closed endbell unit.
First order of business was to take out the stock AM RX and swap in a new Spektrum RX. Since this is a budget truck, I opted for Spektrum's budget RX, the SR300. It uses a bind plug and I was able to bind it without issue to my Spektrum equipped 3PK. Next step was to cut off the Tamiya style plug on the ESC and solder on a Dean's plug. Last step was to install the foam battery spacer. The battery tray on the HIGH Roller will only accommodate standard height and width sub C size packs. It will accommodate a longer 7 cell pack. I decided to run the foam spacer in the rear of the chassis to put more weight over the front wheels.
Checked my trims and then set my EPAs. With max steering throw, the left showed 110% and right showed 86%. I dialed both back 3% to help servo longevity. Next I attempted to reset the ESC but it wouldn't go into programming mode. I went ahead and dialed my throttle/brake EPAs to 120%.
Balance charged my Orion 4800mah 2S lipo and she was ready for her maiden run. More later once I get my kids to sleep.
Some pics
Some pics
