I've been in a fist fight with the 3.4 engine for a few weeks and I finally tore the engine down and I found that the internal bearing is bad. Any idea how to remove and reinstall this bearing without buying the tool?
Also the head button and piston are pitted around the edge. What would cause that? I’m not sure if this engine is a toast or should I rebuild it.
Any suggestions on a mid-block engine with a SG crank?
Thanks,
Codfish
Thanks,
Codfish
