Here is a full list of parts to get a Hyper TQ kit up and running (it can be done cheaper, it can be done more expensive). Its a list I wrote that has some quality components, that you won't need to upgrade much in the future. The only thing not on there would be a set of alloy front and rear chassis braces which I would suggest as well.
This does come in around $1000.00 so you may have to trim it a bit to hit your mark.
- Hyper 7 TQ Sport = 240.00 at ace (car is so upgradable, and so much parts availability, you can upgrade to pro kit off of e-bay as needed)
-JR XS3 Radio = 150.00 ebay (It is the cheapest synthesized radio around. This means you never have a channel conflict again. Also comes with decent servos to get you going, range seems good and its computerized).
-OS RG (p) = 110.00 or 90.00 at tower when they do the $20.00 coupon (great engine, at half the price of engines with similar power)
-Jammin JP-1 or 2 exhaust= 45-60 ebay depending on coating (good pipe for the RG)
-OFNA Chrome top starter box #10250 = 80.00 ebay (12 volt motor, room for a dry cell, and has hookups to run a glow starter off of the dry cell)
-Dubro Pit Caddy = 30.00 (comes with 850 cc fuel bottle, jetting screwdriver, glow plug wrench, engine stopper)
-Byrons 30% race fuel 28.00/gallon @ any hobby store (I have tried Blue Thunder, and Odonnel, and found the best results with this fuel for the above engine).
-OS 8 (or A8, I forget) plugs = 5.00 anywhere (I bought tons of these, because I used to go through McCoy MC-8s alot. I have had this same single plug in the engine for months without fouling!!)
-Mugen Aluminum clutch shoes 16.99 ebay (great hook up, long life)
-Mugen 1.0 springs 3.99 ebay
-Ofna clutch bell 15.00 most hobby stores
-12 volt 7ah battery = 20.00 (for starter box)
-Venom 2400mah NIMH AA batteries (8) 20.00 at tower (for transmitter instead of alkalines, highest mah rating out right now it seems, and one of the cheapest)
-OFNA 6 volt receiver pack 9.00 ebay (don't mess with AA's for your receiver, this will only lead to a low voltage condition and a runaway)
- MRC 977 Super Brain 99.00 on ebay (plug in peak charger that charges 2 batteries at once, can charge/discharge almost ANY battery type used with nitro cars, including 12 volt starter box batteries).
-OFNA PCR temp. gauge 33.00 on ebay (fits in top of engine, so you don't have to worry about lining it up, easy to read display)
-OFNA micro failsafe 17.00 on ebay (Keep your car from going out of control, with loss of reception)
