Look what I just got
Sweet. I hope it works, Ebay has gotten to the opoint that it is almost a "pot luck' either you get something good, or you don't lol!
is it just me or does the top of the block look discolored?? maby its just the pic.. man i hope so.. I've NEVER seen the block get discolored.. head yes block no..
I don't think it's discolored. I think that's where the Header spring probably rubbed against it.
i heard they do not last long at all. get about 2 or 3 gallons if you are lucky. ppl here are going back to the picco 26.
I have seen a block discolored before.I sprayed it with carb cleaner to clean the dirt off..OOPS!!!
Mark
got the engine today! engine is in great shape and has lots of compression
That engine should suit you very well, I run the same one in my savage and it rips. What gearing are you running? I only have a little more than a gallon on mine so I can't comment on longevity.
wannarunem said:
nice mill...when u get tired of it..LMK!!! lol
So how does it perform?
I don't know cause I have no fuel :doh:
SD I am running 15/49 with the 3 speed. What gearing would you recommend with this mill. Also does anyone know the factory needle settings for the .27?
Ran 3 tanks thru it and all I can say is WOW! This engine is ridiculous. Has tons of torque and great topend. I love it. I have already snapped 3 dogbones. If your not running this engine in your MT then you gotta get one! :hammer:
Gear it up 18/47, top speed is going to blow your mind.
Factory setting looked like all needles were flush, my LSN right now is at around 4 and half turns out but I'm still on the richer side.
