I just put in a 120A ESC surpass hobby my motor is a castle 1406-7700kv sensored motor max 100.000 rpms .I'm using a 3s battery I want to put my 4s battery in.will my motor handle 4s? All that in my 104001rc 1/10scale buggy
That motor isnt even rated for 3S let alone 4S. I would not do it. you're just going to overheat it, blow out a motor bearing, and/or frag your rotor magnets. you're liable to eventually do that on 3S. Have you been tracking your motor temps to make sure you have a gearing ratio that will work with that motor on 3S so you dont burn it up?
Crazy to say but I have built a 8s Baja I know you guys know it, I will only run it at 6s do to it’s so much power and yes a lot money went into it.
And also not recommend unless you know what ur doing and you can mod and fab ur own stuff
Yeah I've seen it done but like you said, you have to know what you are doing. I have a suspicion the OP hasn't been into it long.
I run a Typhon Mega on 4s and it's stupid fast but I can't keep her on the ground and it's considered 1/8 scale.
