Greywolf74
I'M TO BLAME!
Lifetime Supporter!
RC Showcase: 8
Ok some of you may know this but this was completely new to me when I ran across this the other day. Just in the nick of time too because I had two bodies to clean. One has had paint on it for about 5,6,7 years? The other one has had paiways on it for about 4 or 5 days. I've always heard that Dot 3 brake fluid is the best and pretty much only way to strip lexan paint off of a body without ruining the body. Well anyone who has ever cleaned an RC body with Dot3 knows that while it does work its a huge PITA and requires alot of scrubbing.
I submit to you the King of lexan paint removal is actually Dot4 brake fluid. I am stripping two bodies right now using Dot 4 and I'm barely doing anything to them. I'm about 2 hours into the process and already have had half the paint come off of the bodies. One body in particular had several thick coats. This stuff is the bomb.....it takes alot of patience as you have to let it sit and soak for 30 minute stretches at a time but there is vertually no scrubbing what so ever. Thank God for Dot4 brake fluid!!! Watch the URC video that explains the technique. Hope this helps you gusy as much as its helped me.
Lexan Paint removal....the easy way
Oh and BTW.....Dot 5 brake fluid doesn't work
