I picked one up about a month ago. I love it. One quick tip though... I had a hard time getting the failsafe setting to hold when binding. It took two people to bind the model. I set the bind mode and held full brake until the light signaled it had completed the bind, kept my finger on the brake and had a friend pull out the binding plug. If I did it any other way the brake setting would not hold. Temp telemetry is easy to install, RPM sensor wire took some routing and I am not convinced it is operating correctly. I run it on a Revo with an "X" type Traxxas flywheel. This flywheel has holes around its perimeter and I think those holes are triggering the RPM sensor at ten times the speed it should. Setting travel and everything else is a breeze.
Traijin
