Jato question
blacksilverado12
I have a jato few months old and I'm noticing a little bit of fuel bubbling/leaking a little from the exhaust side of the motor vehicle runs what i thiknk is pretty good except i lost alot of torque from the start any idea guys?
Exhaust side where? near the exhaust header itself? May just need tightened. Or you have cracked it.
Have you done any clutch maintenance since you got it? If you've run it quite a bit, the shoes probably have glazed over which makes them slip. This could be your loss of power.
hey yea thats a good idea ..i tightned up the head and it seemed to take the leak away...how should i do maintance to the clutch..am i better off just replacing it
Take the CB off and the shoes off, then rough the face of the shoes up with a mild sandpaper or scotchbrite pad. Do the same to the inside of the bell where the shoes make contact.
I usually clean the bell and shoes with DA before installing. Gets any trace oil off.
