WoodiE
Kind of good admin
Administrator
Ok guys I have a screw with stripped out threads in my steering linkage, when I try to screw it out it just turns and turns - regardless of which direction I turn it.
I've attempted to drill it out but the screw is putting up one hell of a fight. It was suggested I use J-B Weld to bond an old allen wrench to the screw so I could pull out while turning. So I bought some J-B Weld yesterday afternoon, which came in two tubes, one Red hardener tube, and one Black Steel tube.
The directions say to mix equal amounts then apply it to whatever your working on. I've done that I let it set over night, get up this morning twist the allen wrench just to test it...tada it turns, so I VERY lightly pull out on the screw and it happens. The allen wrench comes right off of the screw.
So how the heck do you use this J-B Weld? What did I do wrong? I've let it set as it recommened, I've mixed the two tubes in equal amounts and mixed it well, but the wrench just popped right off.
How do I use this crazy stuff?
-Michael
-Michael
