Freezectrl
So I've decided to get my Savage 4.6 running again and it's been nothing but problems
At first, the engine wouldn't crank with the roto start, so I toke it apart and found the starting spring was broken, switched it out no problem there
While taking the engine apart I decide to seal it using RTV silicone copper, again no problem, pretty straight forward
Got it back together, and it is impossible to start, I got it once in like thirty minutes but it was running super poorly, open throttle barely moves it forward then it dies right away. Found that my fuel tank was leaky so replaced the o rings, it now no longer leaks.
Things I have tried up to this point
New fuel
new glow plug
new glow driver
new different glow plug
new fuel lines
having the carb needles at stock
changing the carb needle slightly
changing out the exhaust manifold gasket
After trying to start it today I think I blew the spring again, it barely cranks now so that's another 10$ gone
What else can I try at this point?
The only other thing that I've thought of is the o ring for the high speed needle looks pretty worn as I was taking it apart to add green slime
What am I missing?
New fuel
new glow plug
new glow driver
new fuel lines
What am I missing?
