Well, I got the tank in. Took some nice pictures. Went out and tested.
Ran on Saturday evening, it was not too hot out. The car seemed to be running a bit richer with the new tank. The temperature was roughly the same, and pressure, etc - but I didn't give it much mind, and leaned out the HSN a little.
Ran a couple of times, and while it was faster, it's not where it needs to be - though it was very straight and consistent. Not getting hard launches, so I definitely need to drill the clutch out a bit more. I didn't use any tire sauce, and judging by the sound I saw in the video we took, and by the data, I was losing traction when the engine hit it's power band. Several runs of 3.2s that were 45-50 mph.
I will say though that the acceleration curve was markedly steeper with the 24/66 gears, so I'm definitely on the right track with the clutch, as I think I can attribute that to it hitting in at higher rpm. In the video, I could hear the engine suddenly rev up at around 30 feet or so, and I think that's where the flat part in the acceleration line is.
I went out yesterday in the early afternoon. It was around 80 out, and I noticed that the car would barely stay running. It was spitting a lot of fuel out, and when I revved it, it would die every time. I leaned out the LSN and HSN, but this is a 3 needle carb, and the 3rd needle is inaccessible with the engine mounted, and dummy me didn't have the right wrench to pull the engine. I think I leaned both the HSN and LSN by a half turn, and it was running better, but the mid speed needle was still a problem. But this was weird to me...I've never had to lean it out this far, in any conditions. The only thing different was the 1oz Sullivan tank vs the stock 5oz Slash tank. I managed to bust a couple of runs off, but the engine was clearly not performing all that well.
Again, lost traction at the power band, but also nice steep acceleration at the start.
My final run I think the tires stayed hooked up, but it slowed down at the end, because (and I'll elaborate) I lost radio control.
The car was still spewing a lot of fuel, running very rich. I didn't want to lean the HSN/LSN any further without touching the MSN, so I called it a day. Plus a cop showed up (just sitting in the lot doing paperwork or taking a nap, and I didn't wanna get yelled at, lol). He didn't seem interested in me though
So I'm using the FlySky GT3B, and I've been having issues with the radio cutting out on the big end, sometimes even before hitting the traps. I've got the wire in a tube and pointed up, but inside the body, but still, that's horrible range. It's a 40 dollar radio, so I guess that's deserved, and I need to invest in a better radio for this car. I'm losing radio on every run, so it's not a fluke.
Now, in the "learn something new every day" section...
In my other build, I'm using the same Sullivan 1oz tank, and am finding the engine running extremely rich, even when down 1/2 turn from factory break in settings. Having this same thing happening to Invader made the lightbulb click off - it's the tank. More accurately, it's the size of the tank - and that the tiny tank is generating too much fuel pressure. This is why when revving it, it's stalling - more exhaust, making more pressure, and flooding. So this is kind of tricky, I think. I can, and have leaned out the needles, but I don't want to get it to a situation that when the tank is less full that it get's too lean. My thoughts for correctly dealing with this would be to mitigate the air pressure coming back into the tank. So first, I'm going to try clamping the hose to restrict the air flow some. If that doesn't work, I'm thinking of putting some inline expansion tank in, but that seems a little awkward and adding additional weight. I'll try tonight to run the engine with the clamped hose, to see it it's a little better. At least now though I have the common thread between my two rigs having this issue, and a decent idea of what's happening.
